auto door lock question
LoneRanger
Jacksonville, Fl
the drivers door and the passanger rear door do not LOCK. Buuuut they both UNLOCK?
WTF over?
can anyone help, i am guessing that the electric actuator is shot, where can I find a good replacement that wont cost me 125.00?
thanks!
L.R.
Do they work ok from the other door switch???
Chances are that both actuators are bad in the same direction is a stretch...................but possible.
I would look at the switch first and then the wires. Then work your way down to the actuators. Just go slow with a test light.
Good luck
its the actuators~
drivers door, and passanger rear door, both will unlock, but neither will lock. It makes no difference which lock/ unlock controll you use.
where can I get these parts?
L.R.
Ive got a drivers side for you. Its from a 92. Make me an offer.
