First, I'm really not trying to build my own. I've seen the write-ups, it looks possible, but I've been known to have bad luck where others dont. I'm having headlight issues and I want to make sure that everything works the way its supposed to, and leave nothing to guess(ie: making my own)
If you guys like back stories read on, if not skip to the :helpme:
I'm currently running that $30-40 putco/eaharness and some 80/110 bulbs, and I'm having issues. Low beams aren't turning on, passenger side headlight constantly burning out, wonky relays. Bulbs are brand new and checked, relays are new( < 1 month), fuses are good, replaced the headlight switch, and I have the toggle dimmer switch ready to put in(although I would prefer to return it if its not the fix).
While trying to elementary troubleshoot (switching relays, wiggling wires) something caused the power wires from the harness to start... sizzling where they connect to the battery. Now I have no working headlights(but the orange side lights work just fine, so I hope the whole system is fried). Hence my bad luck, or bad form...
I want to eliminate as many variables as possible, so I unplugged the harness H4 connector from one headlight, and plugged the stock connector in and I have light in that headlight. So right now I'm thinking its my harness since harness = no lights.
I'm going to replace the harness(which I'm happy to do, I think its a pile of junk and I wouldn't recommend it to anyone running high than stock wattage bulbs) Those bulbs were running over 300 deg, and that's with solid ground and power connections. I was also having a problem where I was replacing the passenger side bulb about once every 2 months. I'm going to blame the harness on that. Even had it checked by a mechanic and they said all connections and power looked good, they were stumped, but concerned about the temps..
:helpme:
My question is, is the ARB harness worth the ~$100 compared to others? Why are there 3 relays?
http://www.jeepinoutfitters.com/scripts/prodView.asp?idproduct=601
Is 12 ga wiring sufficient for about $70?
http://www.rjminjectiontech.com/products/headlight-harness
I've seen people post links to suvlights.com, but the site is down for maintenance, so I'm not sure what they're working with.
Edit: Also, I'm running ebay autopal housings. They wiggle a bit after mounting. Is this normal? I know others run them too. I imagine they're gonna wiggle one way or another
:helpme:
