- Lafayette, IN
Yeah, I put my pile under the wrench this weekend doing basically the same 2" or so lift with coil spacers and shackles. We invested around 30 man hours into it with the rear shocks still not on. If you didn't finish up the shackles and have run into any problems, let me know what problem you hit. I had a helluva time with my driver's side top shackle bolt.
Yea Josh, just saw this thread and was going to send it your way so you'd feel better. We broke all four upper shock bolts and the weld nut inside the frame. Total PITA especially when you're mentally unprepared for it.
Mudshack... what year is your XJ? The older ones have 2-piece rear main seals which makes changing them considerably easier (although they leak more often... just can't win).
