bobnoxious
- Marion, MA
but you want me to do it for way cheaper than an auto mechanic's hourly rates even though i need 100's of thousands of dollars in equipment and years of training to do it, right?
yes, you do have to pay for cutting tools, that's worked into the price as it is a consumable. If you have an MRI or CAT scan, do you expect it to only cost you $20 because it doesnt take very long to do? Good luck with that....When I lived in the Virgin Islands, I was a marine mechanic for 8 years. The shop I worked from had the dealership for Mercruiser products and OMC products. The shop had every special tool recommended by both manufactures totalling into the thousands of dollars. When a boat come into the shop for repairs, be it inboard, out board or stern drives, that person was charged the standard hourly rate. We never charged for tools. If we do not have the correct tools to do the job, we do not accept the job. If you have a shop that performs repairs, it is expected that that shop have all necessary tools and equipment to do the job. Correct me if I am wrong but I get the feeling I will have to pay for tools as well as labor. If that is so, do I get to take the tools with me when I am leaving?
Down in Miami, Fl the normal price for labor to do gears is between $250 and $300 all day long and that is per axle. A competent mechanic with all the tools needed to do the job and takes 8 hours to do 1 axle for an XJ leave me with a lot of questions which only that individual could answer.
took me and a friend 5 hrs to do my frt axle and 4 hrs on the rear, thats with them being pre clened bare housing, have you ever set up gears? its not a simple thing if ya wanna be perfectDown in Miami, Fl the normal price for labor to do gears is between $250 and $300 all day long and that is per axle. A competent mechanic with all the tools needed to do the job and takes 8 hours to do 1 axle for an XJ leave me with a lot of questions which only that individual could answer.
what is mechineing?No, I have never done differentials. I do agree that it could be time consuming if one do not have the experience and or proper tools to do it. That is why I take mine to someone who do. However, I have done (Marine) outboard motor lower units as well as stern drives (they are in 2 Z configuration) with gears on top and on the bottom some of which have both the forward and reverse gears in the lower unit. An automobile differential is similar but with a slightly different approach and configuration.
Vanimal, the comparison you use is bad for this topic. A sick person go to a general practioner and pays them for their time. They are then refered to a specialist with special tools/equipment and also pays that specialist for their time. That is two different office visits.
You are correct though in one respect. The office with the most tools/equipment usually command a higher pay scale. That pay scale should already have the equipment usage built into it. You would not walk into a 'Fix-A Flat' place to have your gears setup Would you? I would not. Why? I doubt that place would have the equipment and expertise to do a good job. I took my D44 to a place that had what is needed to do a good job.
I am not questioning anyone's labor rate. I am also not debating the amount of tools needed and the cost of those tools. My gripe is,....it sounds like the end bill will have one charge for labor and another charge for tool useage. OH! and the other guy who have been boasting for years as to how many diffs he set up in the past,....What does he do in a diff in 8 hours? Use his expensive tools to make bearings and axle shafts. Close tolerance mechineing do take plenty of time. Ask me how I know.
$50 per hour is a really good shop rate.
People thay charge over 800 in labor are the shops that rip people off. Mostly run by younger guys. Find a old fashion shop
FIFYYou could at least preface your comment with "I shop at Harbor Freight"![]()
