Wow
- Over there!
Recently I've decided I'm tired of having a computer in my XJ. Entirely. Nope. No more sensors, no more check engine light, no more cat. I've recently gotten an address outside the emissions testing boundry. I want to rip the ECU out and add some extra ventilation holes with my .357.
But how do I make it run? 2 options, carb, or propane. With propane I can basically have fuel injection, without the complicated electronics. I can even eliminate the fuel pump. As far as I'm concerned, the less parts, the better.
In the past I've always thought propane was a bad idea since it cost about the same as gas but is only 93k BTU/gal vs 114k for gasoline. But, recently, the state of Oregon, in their infinate wisdom, have outlawed gasoline entirely, 10% ethanol minimum, so the mileage sucks anyway. (I get about 14 now) I could also have a 250 gallon propane tank installed at my shop and have somebody come fill it at a discounted rate, and never have to go to the gas station again. (pumping your own fuel is also illegal in Oregon)
Anyway, what I'm mostly wondering is if anybody else is actually running an XJ on propane? What kind of mileage do you get? I understand the engine can be modified to be more efficient, and more powerful with propane due to it's 100+ octane rating. Super/turbocharger might be a worthwile upgrade...
(just thinking outloud here...)
