sw_mi_xj said:
the surrounds are so tight on the hx2 and the new p3.( high excursion woofers ) that they will self destruct if you just put them in and blast .
I don't follow. What are you referring to as a 'surround' and what makes them 'so tight'? Those woofers are just average Rockford/Fosgate stuff...
sw_mi_xj said:
some of the guys at the db drags/ boom off's will put them in and not even hook them up until they are ready to test .
I've seen lots of strange people do strange things for superstitious/mystical reasons, doesn't mean it follows science or needs to be implemented.
sw_mi_xj said:
you will get the highest db level possible because they are still tight .
but they may only last a minute or so at 1000 watts. seems like an $$$$ way to win .
Why install something so that it only lasts a minute.
sw_mi_xj said:
so if you want them to last , you break them in for a while at about half volume , 8 hours was the recommendation of my retailer , and i trust his advise .
Makes no sense to me and I have never heard of a retailer advising to 'test' a woofer to 'break it in'. Seems fishy to me.
sw_mi_xj said:
so far even at 1/2 volume or so , and running 4 ohm now vs 2 ohm before they are more responsive and loud as hell .
2 ohms offer less resistance. If you have a 2ohm output amp (never seen one) and you put a 4ohm speaker on it, you will effectively cut the power output in half. For example a 4ohm amp that puts out 440w will only put out 220w of you connect an 8ohm speaker.
I still don't understand this. I'm not trying to call you out, either you have been given erroneous information, or somehow audio has altered incredibly overnight.
When I build a speaker enclosure. I built it solid out of at least 5/8" MDF or 3/4" plywood. Glue it, acoustically seal the enclosure and bolt or screw in the woofers. When I'm done and its dry you can crank the hell out of it from moment one. Anyone who tells you otherwise should be able to explain why they do it another way and show you data to support their claims...
I've built guitar amplifiers and enclosures, bass cabinets, regular multispeaker cabinets, ported and enclosed using dozens of different types of speakers and subs and I've yet to have a problem of any kind...
