He can:
Increase speed limiter (mine is at 254, yah!)
Increase the rev limiter (won't help us with the AW4 as it has a separate TCM)
Increase the idle RPM (stock mine was 648, its now 800 rpm)
Turn the torque management off (effects transmission shifts)
Turn stall torque off (effects transmission shifts)
Adjust fuel map
Adjust timing map (I have 6* added)
Turn cylinder misfire code mil to off
Change the duration the AC compressor turns off under WOT(mine turns off for 10 seconds)
Change cruise control range
Change extended idle RPM, if you have the switch connected
Change other setting for aggressive cams
Convert to a 2 bar MAP and associated maps for forced induction
Disable after cat O2 sensor(s)
Convert to open loop only
That is just what I know about, I am sure he can do more. He is quite good and very accommodating.
