5-90
- Hammerspace
maalox said:That's just it, though - I'm not towing anything. The only rust on my truck is on the factory trailer hitch(the reason I made the concession and bought an automatic in the first place), and it's so bad that I don't trust it enough to tow with it. Regardless, this was occurring with myself and one passenger, and the rest of the truck full(to window level) with camping and hunting gear.
It doesn't drop back out of lockup until it downshifts all the way to third. If it would drop out of "4L" as you call it, and into "4", I would be thrilled, because that's exactly what I want it to do. Instead it bypasses "4", "3L", and jumps all the way down to "3". And at lower cruising speeds, it does "hunt", as it's constantly locking and unlocking. If I drive the truck in "D" for even a short period of time at 25-30 mph, it hesitates horribly and often times backfires if I give it any more than 1/2 throttle. Not so if I drive it in "3" or keep my RPMs up by speeding(which I try to avoid as best I can).
Yeah, but 75mph in 3rd gear doesn't make a whole lot of sense.
And herein lies the problem. I feel that "soft shift" when it shouldn't be shifting at all(hell, it shouldn't even be anywhere near overdrive at 25-35mph), and it won't give me that "soft shift" when it should(1/4-1/2 throttle at highway speeds).
I am a very attentive driver(this comes from years of driving manual transmission vehicles, including some requiring me to hold a CDL), and I have never in all my years of driving experienced this type of thing with ANY other automatic vehicle I have driven.
Hm - I've not had that sort of trouble either (and much of my driving background is similar to yours. I also had a private pilot's license for a few years, which also tends to make one attentive to the vehicle...)
You should "shift down" into 3L - it's always a "shift up" to go into it. The TCU has to read a steady-state cruise before lockup can be enabled. So, the pattern would properly be "4L/4/3/3L", if it's going to go from fourth lockup to third lockup. Sounds funky - but it's actually better that way. The lockup circuit should lock out automatic shifts until it is disabled.
I'm honestly having difficulty trying to figure out what's causing the trouble you're describing - not from your communication (which is solid,) but because I feel that I'm still missing some small datum that will make all the rest of it make sense. Could I talk you into doing something? Open up a Notepad doc (or whatever plaintext editor you prefer,) and just give with everything you can think of that might relate to the problem at hand. Include parts replacements, tests - and make sure you remind me it's RENIX.
Think "stream of consciouness" here - the primary objective is just to get everything down.
After you've worked on it on and off for an hour or so (don't devote your attention to it - you will miss something that way. Work on something else, and shift to it when you get that "Oh, yea!" idea that hits you.) clean it up a bit and get it to make sense to someone else. Then either post it here (preferred) or email it to me (you can, but I'd rather have this out in the open - that way, it's more than just me working on it...) and we'll see what can be done.
I just feel like I'm missing something small and vital - and that's the trouble I have with "diagnosis by remote control." What the owner would think is insignificant turns out to be the case-breaker.
