blondejoncherokee
- sacramento
are you keeping the body cladding?
what do you mean by cladding?
That plastic stuff along the lower trim that's falling off I think
Mine started doing that after the kids broke the clock spring. The cc is messing with the throttle sensor now.
Doubt that the clock spring is the issue on a renix.
If you hold the key between start and run after it turns over does it stay running?
Also, fuel pump ballast resistor bypassed?
Yea a clock spring on the renix is just a horn won't have a drivabilty issue unless something is shorted out in the harness
