043500
- Ocala, FL USA
1) frame plating and move rear spring hangars out to make front leaves parallel. Keeps breaking the spring plate bolts in the housing on the passenger side of the front axle and well...leaves were meant to be parallel so it's time to make them right.
2) rebuild T-case if there time...it's stuck in low and I hate not being able to drive on the street with it...but it's not a problem for the Crawl if I don't do it this go round.
3) fix turn signal gremlins. replaced flasher and had left turn only and that was intermittent due to the old light sockets are OLD. Got new LED rear S<T<T<R lights. Got new LED front turn and markers and did some re-wiring. Now no blinkers at all even manually no matter how I wire it. hazards and markers, reverse and stop lights all work though.
4) fix AC in tow rig.
5) new front uni-bearings in tow rig
6) possibly new rear wheel bearings in tow rig
