XJerome
- Douglasville,GA
I picked up this little jem on saturday for $2,900 bucks. Its a 95' sport with 150k, new main and rod bearings,radiator/waterpump.it runs pretty strong and smooth.interior is clean,not sure of the t-case and tranny.its an auto. a/c works
heres the stuff ...
rustys 4.5 ,quick disconnects.brake lines dropped
spring over axle rear .
rock sliders/bumpers/detroit 8000lb winch/cb
2 compressors/airtank/high lift.
33/12.5 general a/t's just got a free set of 32/11.5 maxxis bighorns(90%)
on stock wrangler rims.
i noticed a spicer u-joint on the rear ds.
it needs alignment pretty bad.the steering is lumpy.it has a small camber problem (adjustable ball joints?) i hope its not my housing..dont look bent.pulls fine no clicks or pops.
temp gauge reads a tiny bit over 210 (normal?) i cleaned out the a/c condenser today. a thermostat is next i guess.
small passenger rear door carnage. ugly fender cut under those tj flares
noticed t-case had one small drip,no oil leaks. changing diff. fluid this weekend and various other things. wish it was ready for cherokee crawl.
let me know what u guys think its my first xj...or any jeep... or any 4x4
-nate
