Biernuts
- Coeur d'Alene, Idaho
I searched but could not find a specific answer to this...
I've been restoring an XJ that had been stored outside for 2.5 years.
I finally got it to stay running (many new parts & procedures later)...
So I drive it around my property trying to get the new tank of gas and BG44K through the system. It still runs rough but at least it's running.
But after a couple of minutes of driving around in 1st gear, it'll stumble and miss when I give it gas, especially up a small hill. In fact it'll stall half the time.
Last night, as I was revving via the throttle cable, I noticed the old, cracked, serpentine belt would oscillate like Tony Iommi's E string between the PS pump and idle pully. It was obviously loose and was going to be changed this weekend...instead it decided to break on me....literally (ouch)
Before the belt broke, I checked the headlights to see if they worked. As soon as I turned them on, the engine started to struggle and almost died.
My question is, could the loose, worn serpentine belt affect the alternator enough to cause a weak spark under load thus causing a missfire?
Already done:
Cap/Rotor/plugs/air filter/oil&filter/fuel pump & filter/O2 Sensor, vac hoses, battery, new fuel & BG44K, EGR appears to funtion but I have a new one to put on (need to buy Torx), MAP appears to work...
Already done:
