jeo said:Mine were too deep to fit in the doors (Type Rs). Had to make spacers.
Can you be more specific about what kind of issues you're thinking about or having?
I did a custom install...all front speakers in the front door - Alpine Type R 6" woofer, 5 1/4 woofer and tweeters. Put my crossovers under the back seat, amps on the back of the back seat and bolted my Focal sub to the floor in the rear cargo area.MY98XJ said:I haven't bought speakers yet. But the speakers I'm thinkin of gettin are the type-s. What size speakers did you put in your car? frt, rear, and roof ?
jeo said:I did a custom install...all front speakers in the front door - Alpine Type R 6" woofer, 5 1/4 woofer and tweeters. Put my crossovers under the back seat, amps on the back of the back seat and bolted my Focal sub to the floor in the rear cargo area.
Alpine Type S are ok...personally wouldn't go with anything less than the Type Rs...but I really love my music...
Are you replacing anything else at the same time? Head unit, adding an amp, anything? Because running stock stereo power into good speakers really won't make a huge difference. It's when you start running better power (a good head unit or amp) to better speakers that you notice major improvements.MY98XJ said:nice setup. basically i just want a direct replacement on my stockers, replace all six speakers...
krakhedd said:I never tried, but I think 6.5"s would fit all the way around (well, front doors & rear roof pods). The stock speakers are (to mine eyes) identical, save for the different part numbers, but the frames are the same exact diameter, including screw holes.
[\QUOTE]
I'm pretty sure there's no way that 6.5s will fit in the front doors unless you do some major cutting of the interior of the door...take the door panels off (it's not hard) before you buy anything and get measurements or ask your local stereo shop. they should have specs on all vehicles.
jeo said:I'm pretty sure there's no way that 6.5s will fit in the front doors unless you do some major cutting of the interior of the door...take the door panels off (it's not hard) before you buy anything and get measurements or ask your local stereo shop. they should have specs on all vehicles.
jfox21 said:^^ did those fit in the rear?
