256offroad
- Huntsville Alabama
Where did you get your freeze plugs? Intown? I'm on the hunt for some brass ones.
I put the r134a system in our MJ from a XJ. Its bolt in and easy to charge/maintain. I recommend using a 96 XJ for the donor. Swap from the orifice block forward.
Sorry for the hijack Alex, just wanted to show it can be done easily on any pre r134a system
cant you get freeze plugs at any parts store?
Dorman 567017 - You will need two packages and will probably have to order them.
mmmmmmmm pie... pumpkin im guessing?
Looks good! Can't wait for the supercharger. Too bad its all time 4WD. 2wd would be really fun with all that hp.
That full time 4wd would give a hell of a launch..
Just my experience... pavement and 4.7 launches don't end well. Neither does hard shifts into 2nd. Or 3rd. Be gentle.
come on man dont tell him that.....now he's curious
I bought a Pacesetter header since it looked like a good deal. The down pipe comes down angling up towards the floor and frame rail. It is dangerously close to the transmission line and the placement of the oxygen sensor bung interferes with the lines. I think I am going to put a right angle piece to dump the exhaust below the frame rail and get a muffler shop to fix it once it can drive again.
The quality on this piece is questionable. :/
What pipe are you going with? I did 2" from the manifold and a Flowmaster 40. The one time I have had a shop do something on my jeep they ran it too close to the oil drain plug and passenger floorboard.
