Theres a simple solution to that problem....convert your AC over and just carry a small, cheapo 12V compressor as a backup.
I use the inverter/compressor like you were wanting info on...i cant really recomend going that route unless youve already got a compressor that will work....but even for a 1HP compressor, your gonna need quite a inverter that will cost some bucks! My compressor has a 1/3 HP motor on it and i run it off of a 800 watt inverter and it BARELY starts it up....once it gets running, its fine however. Depending on the amperage draw, youd probably need one in the neighborhood of 1500 watts continuous and those arent cheap. Its still nowhere near as fast as some other off-road specific compressors, yorks, or CO2, but its fast enough for me and doesnt cost a thing to keep it going(i.e, filling up CO2 tanks, etc). IT will fill up 33x12.50s in about 2-3 mins a tire from 8 up to 30 PSI. I bought a clip on tire chuck and just stick it on there and do whatever else i need to do before heading home(reconnecting swaybar, packing things up, eating a snack, etc). If and when my AC dies, im going to switch that over to an OBA system....probably one of the fastest, if not the fastest way to air your tires up for basically free(other than the initial cost of converting).
