Air bag light and Rear gate wiper
halmca
Tallahassee, FL
No, this is not a belated April fool's joke! Even tho it sounds like one.
When I start my '98 XJ, 4.0L, AW4, 4wd, the airbag light comes on momentarily, goes out after a bit, then comes back on after about a minute pause, stays on for another four or five minutes then goes off.
But that's not all:
Now this is no sh*t: During the time that it is on, my rear gate wiper won't work. When the airbag light finally goes out, I can then and only then run the wiper.
WTF?
In all other respects, particularly of the electrical items on the Jeep, all is normal, including, inter alia the front wipers. I have pored over the wiring diagrams in the FSM and find no commonality between the airbag and rear wiper circuits.
Has this happened to anyone else and if yes, how'd you fix it. Oh -- and the grounds all seem tight and otherwise secure.
PS: I don't care whether you would just ignore the airbag light. I have a close friend who would have left our planet a bit early but for the airbag. I want mine to work.
Well the clockspring is the culprit for the airbag light, can't help with the wiper. On "Lil Sis" the airbag light has been on I bought it!
Well, just make sure you're in good shape with Gawd. It could come in handy. Now back to my question . . . . including, if not especially, its last sentence.
I would check the connector to the Air Bag Control Module. ABCM.
Still no idea what one has to do with the other but.......
Figure if you can get the air bag light to stay off then....
So disconnect the battery and let is sit for at least 5 minutes before you mess with it.
You also might want to disconnect the Airbag Quick Disconnect.
https://www.cherokeeforum.com/f2/acm-99-a-200560/
So my ABCM is under the console.
I think I read they used to be under the driver's seat but they had problems with it there and relocated it.
So I don't know if that is true and don't know when the change was made if it is.
So you might want to research that.
It's a sobering thought that many people have been injured by their airbag deploying - sometimes for no reason. However, to put OP's mind at rest, the fact his warning light does go out, albeit after a rather protracted test sequence, rather suggests the system is working.
Yes, Ralph, the module did used to be under the seat & having had to replace the similarly located one on a Cadillac Seville STS (it was covered in a sort of white crystalline mold) I can understand why Jeep decided quite early on (iirc) to move it.
Some folks have been injured by air bags -- and some folks have swallowed their tooth brush and choked on it. But intuition tells me that brushing my teeth is a better course than not doing so.
My airbag light does go off occasionally, but it is on most of the time. And on one rainy day, I accidentally discovered that the airbag and the rear window wiper are linked, at least in spirit, if not electrically. Bizarre as it sounds. It was funny at first, but the giggles have subsided.
My air bag control module is under the console, which makes me wonder whether Jeep/Chrysler ran a power supply line back to the module, and figured that since they were half way to the back, why not tap of a little hunk of 12VDC to feed that wiper. On my XJ, I have to remove the seats to gracefully remove the console, so I'm not straining at the bit to take that measure -- but may have to. I think I'll start at the wiper motor and move forward in the car until I find some juice.
Counterintuitive, cuz I figure good engineering would demand that the air bag be powered on a dedicated circuit, with no kibitzers along for the ride.
Anyhow, please keep them observations coming. If when I figure it out (irrespective of whether by myself or from suggestions on this excellent forum) I'll publish the cure here.
Even though you say there is no commonality in the airbag wiring the rear wiper wiring, it sure sounds like the ABCM and rear wiper are on the same power circuit. Do they share the same fuse? Is it possible that a previous owner did a wiring hack? Might be interesting to try individually pulling the fuse that serves the rear wiper and then the ABCM.
Made me smile but not a good point: swallowing a toothbrush is a freak accident - being injured by an airbag is rather too common.
Does the light being on necessarily mean the ABS isn't working? I've never been sure, but then I've never been able to get my head round how that one light can confirm the system's working and warn you it isn't. That said, I do understand why you want it to work properly.
I'd be very surprised if you do have to remove the seats to remove the console - 'cos I didn't. Not sure about graceful, but wasn't too difficult.
ABCM has 2 fused supplies, I assume one permanent hot, one ignition on - & the rear wiper has its own fuse.
Point on the toothbrush: one does not throw out he baby with the bathwater. Airbags are not perfect -- but the ratio of 'saves' vs. failures suggests with overwhelming force that their use is prudent. Or to put it differently, I ain't gonna pass up a donut because it has a hole in it. That said, this is a discussion that demands a table outside, preferably overlooking a body of water. Comradery as the principal ingredient and difference(s) of opinion are subordinate, and the discussion lubricated with ones favorite ale.
I think -- but do not know -- that if the airbag light is on, the airbags won't work. Testing that theory, however, would be tough on my jeep and on my fat ass, so a theory it remains.
LOL, re your hesitancy to trust a light that tells when a device is not working. A lovely logic problem. If it's not working, LOL, how are we to trust what it says about itself? Say, HOW DO IT KNOW?
Because of the inexplicable co-incidencent failure of the airbag and rear wiper, I have suspected energy/electrical circuit -- source and ground. So here's a serious question, w/o the logic issue: if the "airbag light" illuminates, does that not necessary show that the module is receiving juice?
On the console removal, I have discovered the hard way (my usual professor) that it's easier to bite the bullet and remove the seats. I've done it enough enough times to be able to grab all the right tools out of the box on the first trip.
Thanks for your engaging in my issue. It is much apricated!
Point on the toothbrush: one does not throw out he baby with the bathwater. Airbags are not perfect -- but the ratio of 'saves' vs. failures suggests with overwhelming force that their use is prudent. I don't have any stats, so I don't know but I do have an aversion to secondary safety: there's just something weird about making vehicles safe(r) to have accidents in, rather designing/building them so as to be less likely involved in an accident.Or to put it differently, I ain't gonna pass up a donut because it has a hole in it. That said, this is a discussion that demands a table outside, preferably overlooking a body of water. Comradery as the principal ingredient and difference(s) of opinion are subordinate, and the discussion lubricated with ones favorite ale. Hmm, perhaps I should review my opinion of FL being one state I had no particular wish to visit ;)
Yup, I agree with all that but - when the light first comes on, it's supposedly telling you they are working - that is the bit I just don't understand.
When a warning light comes on, it might suggest all sorts of things but it only proves that the light works: obvious example is the oil pressure w/l, could mean failing bearings, might just be very low oil level, most likely bad sender.
For the same reasons, I have the same suspicions but find it difficult to believe they can be connected :doh:
No idea what the ABCM circuitry is although you're probably right - but it has 2 supplies & only one working would almost certainly trigger the light. Then again, if that's right, how would you know the module wasn't working for want of juice - 'cos the light wouldn't come on. All in all, a bit of puzzle.
I've only removed 2 consoles, but it never occurred to me to remove the seats first nor afterwards that it'd been easier if I had (not that it's particularly difficult - providing the outer rear bolt hasn't rusted solid!), especially given the weight of power seats - but we can only speak as we find.
Thank you for your kind words, wish I could've been more help. f-w-i-w, my best (uninformed) advice is, concentrate on the ABS as it's important (& an inspection fail here!)
SOLVED! Well, sorta:
Pretty sure its the ignition switch. I have learned that when I get ready to drive MY XJ, and if the airbag light fails to extinguish within the normal 15-20 seconds, I need only shut the XJ off, rip the ign switch on and off three or four times, and everything -- including the airbag circuit and rear wiper will work just fine.
Someday when I have a rare burst of energy, I will replace the ign switch.
Hey, When I got the stuff working I hardly looked back. Love your last response -- witty and on point. So otherwise lacking on the i'net. Thanks.
