Aftermarket coolant temp sensor?
jchevy
Tucson, AZ
Im going fully buggy with my cherokee and going to be running aftermarket gauges. Does my computer need the coolant temp sensor in the t-stat housing? How/Where can I hook up an aftermarket coolant temp sensor?
91+ (I'm supposing since u have a sensor in the tstat housing) That sensor sends info to the computer which gives resistance and also tells the computer when to switch the efan on. So, I guess its important. I'm not sure if theres another sensor for you gauge
I have a Renix so I have a temp sensor in the block and one in the head which sends to the gauge. I beleive you also have one in the block so I'm not sure where this is going now but were getting somewhere
Yup. Sensor in the rear of the head is for the dash only. Idiot lights have a simple go/no-go sender, full gauge panels have a ranging sensor. The ECM reads temp from a sensor at the front.
Edit: I have a 94. Your 93 should be darned near identical.
