After I wired in the UEGO input, I verified that the laptop display matched the gauge. Not too surprisingly, the AEM F/IC UEGO input cals match the AEM Wideband. I went with the AEM wideband just for this reason. I have to spend the next few days recovering from yesterday. Way too much done...
XJCasper, If you do a search on the AEM Forum for "Jeep 4.0", you will find a very nice thread that has a PDF attached. THe PDF gives a connection chart for the F/IC6 (and the F/IC8 as it turns out) showing the PCM connector, the PCM connector Pin Number and the AEM wire color and designator. Pretty much everything you need.
I mounted my F/IC above the Brake Booster, I'll post a picture later. As my air intake is a good 6" lower than the F/IC, I figure that I will have bigger issue with water before it gets wet. Actually, I just power washed the engine a couple of days ago to get rid of the coolant that sprayed from my failed, original, upper hose.
Mr. Yan... One can only hope that you will not drag yet another thread down the drain. But, to answer your inquiry, at no time did I ever tell you to get a Perfect Power. What I strongly suggested was that you buy some sort of controller and install it. Given the two plus years that you have wasted on a used system, doing nothing, one can only wonder just what, exactly, is preventing you from being successful. As I see it, the only thing stopping you is you.
As as yet another courtesy to you, Here is a list of AEM parts that will provide one possible solution. I am in no way stating that this is the only solution or even the best solution. Just the one I and others here have chosen.
AEM Part Number Nomenclature
30-1913 F/IC6 (No Speedometer Correction available)
30-1930 F/IC8 (With Speedometer Correction)
30-4100 Air Fuel Ratio Gauge
For the Fuel Injectors sizing, that would be determined by whether or not there is an intent to run E85. I will be building an E85 Map so I am using 40 Pound Injectors.
