Kind of my point. As I understand it, in order to use the acceration pump simulator portion of the F/IC, does not the F/IC6 have to have a firmware change?
At the time I made the decision, I carefully read all of the posts on the AEM site. There were a ton of complaints with regards to firmware updates on the F/IC6 and none on the F/IC8. It was one of the deciding reasons for me, but not the only reason.
It is odd though that the z107 works fine for Talyn and h-townxj is having issues. There must be other factors here we are not seeing.
My Kid will be here at the end of the week so... Once again I will be attempting to push the timing. He will run the laptop as I try to force detonations. As of this date, with the very conservative ignition table in use, the KS-4 knock sensor is reporting a detonation free engine.
But, at the end of the day, as long as the hardware does what you want, does it reallly make any difference which F/IC is used?
Here is a thought. We could use Dropbox as a clearing house for F/IC programming if there were an interest in sharing. Many sets of eyes are better than one set. Or, just directly email them.
I would be willing to share my set of tables even though the program cannot be loaded, directly, into a F/IC6. I would do it just so qualified others could give constructive feedback. All that one would need to do is download the "Beta" F/IC8 programming (ver1.06) software to be able to read the file. The 1.05 version does not contain the acceleration pump simulator and will not read my current file owing to the configuration differences. Although I do have a saved copy of the previous version, just in case... My fuel and ignition tables will look odd to you stroker guys as there are 40lb injectors in the Heep. Plus, you need to keep in mind I am successfully using forced induction.
What are your thoughts on pooling programs? Yes, No, Drop Dead Fool?
