The F/IC operates under the parameters that the end user assigns to it. The narrower the range of PSIa, the better resolution the fuel and ignition maps have. This is obvious. As I must account for sea level to 14k', owing to my circumstances, my map resolution is thereby limited. Also obvious. By splitting the maps in twain, better control over the fuel/ignition will be achieved. Again, obvious.
At WOT, the XJ is in Open Loop and is ignoring just about every sensor on it. The only times the Heep is in Closed Loop is Idle and Cruise. Period. If the throttle is moved greater than what the Cruise Control System moves it, resulting in either Acceleration or Decelleration, the Heep goes Open Loop. This is not a debatable subject. Look it up. I have verified the operation with my OBDII reader. Only Closed Loop at idle or steady state throttle. Road speed is not a factor either. For the PCM, there is no difference between a 25mph "cruise" and a 75mph "cruise".
The PCM takes a snapshot of the altitude at start up. The logic is ignition on and zero RPM, pre-crank. Once the crank is initiated, the PCM "freezes" that altitude reading until the engine is restarted.
Look it up. All of this is right out of the Factory Service Manual.
With the Heep in Open Loop, it is the F/IC that will determine the AFRs and the Ignition. At least it will when using all 6 injectors. How well the F/IC manages the AFRs with the seventh injector remains to be seen. There was not any testing done by Boostec. They just bolted a F/IC in and called it a miracle cure.
IMO, the AEM F/IC product lines are one of the easiest systems to program when compared to others. The Perfect Power I had previously was not only a nightmare to actually program but, the ignition was completely locked away from the end user's adjustment. The only way to control detonation was to throw fuel at it until it stopped.
You have choices in the programming. Personally, I use percentage as it makes the math very straight forward when correcting the maps. If I need an 8% change to the AFR, I dial the cell by 8%. What could possibly be easier?
When I corrected the Speedometer (I use the F/IC8 (AEM part number 30-1930) just for this reason) I took the heep out to the highway, zeroed the trip odometer at a mile marker and drove 50 miles. Looked at the error, did the math, applied the -10.9% correction value in the frequency table and drove back confirming that it was now less than 0.1 miles off in 50 miles. I have since ran it a full 100 and the error is still less than 0.1 mile. That makes it less than 0.1% off... Not bad for a Heep running P285/75R16s with 4.56:1 gears.
