KSXJ
- Kansas City
JEEPZZ said:I had one built for my Jeep about 3 years ago. I was going to go with something like the Cross design but what I had built instead looks an awlful lot like the JKS set up.
Mine, like the JKS, bolts into the upper shock mounts and also has 3 different places on where to mount the upper end of the shock. With the top of the shock angled in (rather than almost vertical like stock), it allows for much more wheel travel without the need for cutting through the floorboard.
I still needed to reroute the exhaust and you'll also need to run a stiffer shock to compensate for the mounting angle.
Now the bad part, last year in Moab I was haulin' ass down a dirt road (Jeep Speed style ) and tore the unibody away right where the new shock bracket mounts into the stock upper shock mounts. I had to have the 'sheet metal' welded back together. Definitely not the strongest set up.
I'm going to have to add a cross support that will attach out to the 'frame' rails in the same area where the Cross Shockhoop mounts up for extra strength.
With hindsight of the sheet metal strength issue in the upper shock mount area, I'd just go with the Cross Ent design instead.
I don't speed in my jeep except on the highway on the way to the trails. Do you have any pictures? If you do get rid or it, want to sell it?
