ROKRWLR
- Arvada, CO
If you have one lower shock mounted on the front and one on the rear of the axle (like the factory set up was) I'm not sure if the cross would work or not. You could give them a call and ask. You couls also ask if they will cut you a deal to sell you just the hoop with no lower mounts since you've alreay done them.
If they say that both shocks need to be mounted to the front of the axle, and your mounts aren't that way, you'd need to do the JKS or redo your lower mounts, too.
Take a look at the picture on their website, and you'll see what I mean about the lowers.
Hope that helps????
Hope that helps????
