Ac relay electrical issue
Intellect
Tampa Florida
Who likes electrical work!? Heres a doozer
My ac clutch/ac will only work with a jumper wire in placement of the a/c relay under the hood.
BRAND NEW condensor, drier, pressure switch, expansion valve, used compressor.
The switch on the dash works fine. As long as i remove the relay under hood and place a jumper wire.
Ive tried a new relay... Nothing... Jumper wire works fine.
With jumper wire in, click ac on, clutch comes on, ac gets cold, electric fan will kick on after a bit, everything seems fine.
Any help is appreciated
To my knowledge im not doing a traditional 30/87 jump,
Idk how this would mess anything up, but im doing 87/85 jumper wire.
87 is constant 12v
85 is from the switch
30 is to compressor
86 is ground
If im following correctly.. and if what ive googled is correct for my 1995 cherokee i6 4wd country
Sent from my Moto G (4) using Tapatalk
Left and bottom position.
