Remember with ABS that you should cycle the ABS pump when bleeding the brakes. You might get away without this if you limit how much fluid runs out while you are changing the lines. I've had good luck using flexible plastic caps that fit tightly over the end of the hard brake line while you are getting everything else ready.
golf tees will work also. I haven't done it myself but I've been told that fun tack (poster putty) works too. But get all of it off the fitting before reassembly!!!
