hey, im thinkin its about time to make list of all the lingo we use here. it would be cool to make it a sticky too... so this is what i have figured out:
IIRC - If I Remember Correctly
SPOBI- Stop Putting Out Bogus Information
HTH - Hope This Helps
IMO - In My Opinion
IMHO - In My Humble Opinion
CE - Check Engine
TC - Transfer Case
TPS - Throttle Position Sensor
NSS - Neutral Safety Switch
CPS - Camshaft Position Sensor
TIA - Thanks In Advance
BTW - By The Way
ROTFL- Rolling On The Floor Laughing
NHV - Noise, Vibration, and Harshness
BPE - Bar Pin Eliminator
LCA - Lower Control Arm
UCA - Upper Control Arm
CV/dshaft - Not a true Constant Velocity as it would seem, but actualy a near constant velocity, double-cardan-style universal joint shaft, commonly refered to as a CV joint.
there are no true Constant Velocity shafts on Cherokee's unless someone has gone way outside of themselves and made something to use one.
TSB - Technical Service Buliten
FSM - Factory Service Manuel
HO - High Output
VSS - Vehicle Speed Sensor
IAC - Idle Air Control - also refers to Idle Control Vavle
OBD-II - On Board Diagonostics (Type 2)
ODB-I - On Board Diagonostics (type 1)
welp thats all i got, feel free to comment and add more... just trying to help others out...
