Andrew T
- Houston, TX
I have front and rear power trac no-slip lockers, and I need to change the fluid out in my diffs. I know with a limited slip you have to put some kind of friction additive or something... do you have to add anything with that kind of locker? Also, for a daily driver that sees moderate trail use, what weight of gear oil do you recommend?
TIA,
Andrew
TIA,
Andrew
