This is all based on Mini Baja junk, but the process is the same.
So after you spend all the time making your link suspension work, and making the tabs and mount your air shocks, and cycle the suspension, making sure the suspension doesn't bind, Take it out for a spin, and see what you think you need to do.
Keeping in mind that nitrogen is compressible, and oil is not. More oil = stiffer spring rate, less oil = softer spring rate. there is a recommended oil level for each different shock, Polyperformance lists these for Fox Air Shocks on their web page here:
http://polyperformance.com/shop/Fox-2.0-Air-Shocks-p-102.html
We are tuning 8.5" travel 2.0 Airs -
Part Number: 980-99-016-A Travel: 8.5 A/S Extended: 24.09 Collapsed:15.59 8.5 Oil Level: 200 cc Price:$225.00
This is the oil level they come from the factory with, and the recommended oil level.
Knowing this will allow you to tune - either adding oil or subtracting it to match your needs. Start with large, drastic changes (20-30cc's of oil level) and then you get a ball park, rather than making 5cc changes right away. 5cc's makes a large difference in the feel of the shocks, and generally I end up tuning to about the 2cc amount. Adding oil is MUCH easier than subtracting.
Oil is set to determine the spring rate, nitrogen is set to provide the ride height.
any way, we installed ours, and drove them, and felt that the front end was WAY too stiff, so we knew that we needed to take oil out.
after jacking the vehicle up, and taking all the weight off the air shock, bleed the nitrogen out - the schrader valve works well... Draining quickly can cause the shock to burp oil, draining slowly keeps the oil in the shock
then you want to invert the shock, and drain all the oil into a container, and measure the volume -
This allows you to verify the number listed on PolyPerformance, and gives you a baseline to compare too.
slowly depressing the shock makes the shock oil come out....
after you've got most all the oil out, and measured, pull the whole shcrader valve off, and clean the whole area - this will make adding oil easier.
To determine the MAXIMUM amount of oil your shock can take, compress the shock all the way, fill with oil till it wont take anymore, then dump it out, and measure the volume. Any more oil than this, and your shock wont have full travel, and will hydro lock. This will also be the stiffest spring rate you can run... (keeping in mind that the spring rate is not linear, but progressive through the travel)
I have approx 215CC's of oil here (measured in a graduated cylinder later) and guessed that I burped out and lost to the floor from overzellous shock compressing about 5cc's more, so 220cc's.
Knowing that I needed less, I got new, clean shock oil, poured our 180cc's into a beaker, and used a syringe to insert the oil into the shock.
I used the graduations on the syringe to verify my amounts -
after getting all the oil into the shocks, put the valve back on, put the shock back in the vehicle, (still fully extended), and get your nitrogen source ready.
We found our Nitrogen regulator to stop getting higher pressure at 150psi, so note that regulator selection is important - High pressure regulators are required for the 0-550? psi range the shock can take. Also expect to be doing this MANY times, so buying a Nitrogen kit from Poly Performance isn't a bad idea...
Select the amount of nitrogen to put into your shocks - kinda arbitrary in the beginning, but after a short while, you'll get good a guessing.
We use a Fox Shock charging tool with a built in gauge -
This screws onto the outside of the schrader valve and allows the user to 'overcharge' the shocks, then finely bleed down the pressure to the desired pressure.
NOTE: always charge shocks at full extension with no load on them -any other way will give you bad readings, and you wont be able to baseline the number...
Charge the shock, then put the weight of the vehicle on it, jump up and down, shake the rig around, then look at it. Measure your ride height. More nitrogen will make it higher, less will make it lower. Jack it back up, and add or remove as necessary...
Then repeat on the other side.
Re check that all your bolts are tight, that your limit straps are bolted tight, go for a spin around the driveway, up the block and back. Hit a curb at speed, crawl up your trailer, then pull back into the garage, tear it all down, and re-do it till you get an acceptable spring rate....
very much an iterative process.
