xj-grin
NAXJA Member #1096
- Colorado Springs, Colorado
lookin secksy, Rich.
I can't believe this garbage is allowed here......... I thought this was a damn XJ forum not a sissy CJ, TJ or WJ hangout.....lastara........:moon:
I believe the MC application was for 4 wheel disc brakes with hydroboost, i.e. larger bore to push more fluid (IIRC 1.125" bore vs. the Jeep 7/8" bore)
Exactly,I've talked to a guy on Pirate that is currently building an Ultr4 rig and will be competing in KOH2011 with it. This was the exact master he recommended and is using on both that rig and his YJ crawler. Both are on 40's and running 1ton brakes like me.
I originally had it setup at 5* up (thats where the stock perches set it) to match the t-cases 5* down. The problem there was that it wouldn't spin because the t-case side was binding at ride height.
After talking to several driveline shops they said that even though i was using a single cardon setup to just go ahead and point the pinion either at the t-case or 2* above (like you would for a double cardon/c.v.). They said it wouldn't be a problem for a trail rig because I won't be doing highway speeds. Keep in mind too that when I install the offset u-joint at the t-case there will be no such thing as a vibration free driveshaft. Not that it should matter as its a trail-only vehicle.
WOW.........
Several driveline shops told you that????? Hmmmmm....... I am glad I do my own work!!
