Since I did my relift on my XJ I've noticed a couple of weird things that I have not been able to fix using search, allthough I have gotten a lot of ideas as to what It could be.
1. When i make a right turn up a curb/driveway I hear/feel a loud clunk or pop. Very brief, yet pronounced and annoying. Through the search I found out It could be:
trackbar, loose bolts, loose lower CA's...
The bolts are good, I got the alignment done, I've checked the LCA's
and the track bar does not seem to look much different from stock unless I don't know what to look for. Which is extremely possible.
2. I have also noticed that my new RE 3.5's are spreading or fanning, WTF???
Seems like if I air down I'll rub the leafs.. This can't be that good.
Will this correct itself as the leafs settle in?
I'll try to get some pics of this up for you all to see.
My lift consists of RE 3.5" in the rear w/1.5" shackle & 4 degree shims, 78' F100/F150 coils w 2" spacers & JKS's, basically an adaptation of lunghd.com's, Just instead of using the stock leaf/dakota leafs I bought a set of RE rears.
I think the ride is good, and the springs are still settling in. I had read a lot of people putting down the ride quality of those fronts, but I don't think they ride bad at all. I don't have a SYE and so far have not noticed any driveline vibes.
Here's a couple of pics with the lift installed
Sorry they are soooooo big
