A/C changes vents as you speed up???
Stone Dragon
Peoria, AZ
I have a '99 XL, and when you press on the gas, the a/c air will change from the dash vents, then to the defrost, then to the floor. If you let off it will come back to the dash vents. Any Ideas? It acts like a vacuum issue. I have a Ford escape doing the same thing, just not as bad. Thanks!
Stone Dragon said:
I did! I moved it for a new bumper.
you've got a leak! check the hoses and you may want to clean them out as well
