RickyN29
- San Jose, California
Okay, I finished the job. Incredible results. I will have a little write up coming soon. (if anyone even checks this thread anymore!)
The basics though:
The factory circuit is designed for 25 amps. The circuit can only handle 15-20 amps MAX without overloading (due to age, wire corrosion, etc)
The blower motor on MAX draws 16-19 amps, the compressor clutch draws another 6-8amps. This is running the circuit at more than 100% of capacity, hence hot wires, inconsistent performance, and blowing/melting fuses.
I have rewired and created a new, 40 amp circuit. Constant draw on circuit with everything on MAX is 20-25 amps, so the circuit is only at 50% capacity and corrects the problem.
Everything is verified on DC Ammeter +/- 3%
The basics though:
