99 xj 4.0L with 188k miles
I have some questions about getting the head cleaned/rebuilt. I've done some digging around but still feel unsure of it all. My engine is pretty much completely disassembled at the moment, so I've had several people tell me to remove the head and have it cleaned/rebuilt while I'm at it.
I'm going off of this thread:
http://www.cherokeeforum.com/f67/cleaning-pulled-head-166981/
So, basically, remove the valve cover, then based off FSM I should see 2 Cylinder Head Bolts. Once I remove those, the whole head should come out as one giant block with the valves and springs and all attached? Like so:
So, then I just take that whole block as-is to a machinist and get it hot tanked, then checked for flatness. if warping >.002" then have them refinish it. Do I need to have them check anything for valves (like this three angle valve job I keep reading about?) Can I also just ask them to see what needs to be rebuilt (new seals, rings, whatever) and they would know what to do?
Once its all clean, get new cylinder head bolts and a head gasket then reinstall via FSM? Is there any painting that needs to be done? Someone in that thread said to paint it before reinstalling.
What price should I expect to pay for just a cleaning? I would like to have this done as I doubt I will have the engine this far disassembled ever again, but I don't want to spend tons of money on it. I want to make sure I know what I'm doing when I go into the machinist so they don't smell green on me and start trying to scare money out of me.
If you want it cleaned right take it to a head shop and get it hot tanked, not too expensive for just a clean job. Real simple just drop off and pick up throw a quick paint job on and be done. This will get all the internals ports and such.
