woodkrawler
- Charlotte, NC
The time has come to take a much needed break from 4wheelin and the Jeep so it’s officially for sale. Many things have changed in my life since starting the MJ build a year ago and it’s time to move on. That being said I’m really happy with how the truck turned out and I’m sure the next owner won’t be disappointed. It runs really good, everything works inside and out as it should, it will cruise on the interstate at 70mph with the A/C blowing ICE cold, and then tackle moderate to hard trails. The truck passed NC inspection in June of this year with no problems. I have a folder over an inch thick full of receipts from the build as well as over 500 pictures from beginning to end.
Detailed info and pics can be found in my build thread on JeepForum: http://www.jeepforum.com/forum/f22/99-mj-build-881250/
Below is a listing of the highlights of the truck:
Body
1990 MJ - Unibody/Cab – RUST Free – Clear Title
1999 XJ – Doors, Fenders, Hood, Grille, and NEW Safelite Windshield, tinted door glass
Professional body work and paint job (Jeep Silverstone Metallic paint)
New CR Lawrence tinted sliding rear glass
Custom Rear 10g steel Bed/Corner Guards with LEDs
Rigidco Hybrid XJ/MJ rear bumper
Rigidco XJ/MJ Front Winch Bumper
Northern Tool Low Profile Black Tool Box
Interior
Agate interior was transplanted from the ’99 XJ
NEW Agate color carpet with double thick padding
NEW Wet Okole Seat covers with heating elements
NEW Headliner
Power Door Locks, Windows and Mirrors
Keyless Entry
MTX 7 Speaker Audio System including Amp and 8” Sub
Kenwood KVT-514 In-Dash DVD System with Garmin Navigation Add on
HVAC Unit was rebuilt while out with NEW Evap Core, Heater Core and Blower Motor
Powertrain
4.7L Jeep Long Rod Stroker Engine Professionally built by Midland Engine
12cwt Jeep 258 Crankshaft, ARP Bolts, Jeep 4.0L Rods, Keith Black Forged Pistons, Moly Rings
Port-n-Polished Head, NEW Sealed Power Valves, Mopar Perf Springs, Locks, Retainers, 3 angle valve job
Harland Sharp Roller Rockers
Pacesetter Long Tube Header, Car Sound HiFlow Cat, Flowmaster 40 series muffler
AEM Brute Force Intake, 63mm Throttle Body, 24lb Ford Blue injectors
Accell 8mm Wires, Cap, Rotor, and Plugs
Hesco HiFlow Tstat housing, 180* Tstat, FlowKooler Water Pump, CSF Three Row All Metal Radiator
AW4 Automatic Trans
NP231 Transfer Case with P.O.R.C. Slip Yoke Eliminator
Rebuilt front and rear CV Driveshafts with Spicer joints by Universal Service in Charlotte
Drivetrain/Suspension
Rear MJ Dana 44 Axle, 4.88 Yukon Gears, Full Case Detroit Locker, Ten Factory Alloy Shafts, ZJ Rear Disc Brake kit with New Rotors, Pads and ebrake Pads, Ruff Stuff Simple Swap Kit, SOLID Diff Cover
Front XJ HP 30 Axle, 4.88 Yukon Gears, Full Case Detroit Locker, Alloy USA Shafts, JKS Mini Skids, Currie CorrectLync HD Steering, SOLID Diff Cover, 4 New MOOG Ball Joints, New Ceramic Pads, New Brake Rotors
Front RockKrawler 3-Link Long Arms, RK 6.5” Coils, JKS ACOS Spacers, JKS Sway Bar Disconnects, JKS Bar Pin Eliminators, Extended Stainless Steel Brake lines, Bilstein 5100 shocks
Rear is SOA with Ruff Stuff Simple Swap Kit using the MJ rear Leafs, Extended Stainless Steel brake lines, Bilstein 5100 shocks
Tires/Wheels
Goodyear MT/R with Kevlar 35x12.5r15 Tires mounted to 4 Matte Black Alloy 15x8 wheels
PRICE - $15,000
PM me with questions or for my phone number if you want to talk more I’ll be glad to provide more pictures and answer any questions.
Body
Interior
NEW Headliner
Keyless Entry
Powertrain
AW4 Automatic Trans
Tires/Wheels
PRICE - $15,000
