98 XJ - 5.3 LS Lots of other mods
racer32
Idaho
Up for sale is my 98 Cherokee. I have owned it since 2007 and have spent countless hours and a lot of money, blood, sweat and tears modifying it. However the time has come to part ways with my beloved Jeep. I have invested over $10k in parts/mods. The list below is everything I have done to this Jeep over the 11 years I have owned it. This rig is by no means perfect and has a couple small issues listed at the bottom. It's a pretty typical lifted XJ in regards to driving experience.
Link to the LS swap thread:
http://www.naxja.org/forum/showthread.php?t=1127403
$7500. Serious buyers only.
Suspension:
-Rubicon Express 6130 Super Flex kit
-Rubicon Express HD track bar & Bracket
-RE Steering Stabilizer
-JKS quick disconnects
Axles:
-Dana 44 - Explorer disc brake swap w/ ZJ rotors, Truetrac, 4.10s
-Dana 30 - ARB, 4.10s
-ZJ tie rod
Drivetrain:
-05 5.3 LS V8
-LS1 intake/injectors
-F Body exhaust manifolds
-All new sensors
-All new gaskets
-All new seals
-Custom 2.5 to 3" exhaust with Magnaflow cat & muffler
-Griffin aluminum radiator
-Volvo 2 speed high CFM fan
-4L60E
-Transgo Sk Shift Kit
-B74020AH - Hi energy Band
-A74624D - Hardened Shell
-A74658B - Sprag
-E74010EC - Filter
-34435B - Pressure Control
-Solenoids
-1200 Stall Conv
-New internal harness
-Corvette Servo
-Transmission cooler
NP231 Hybrid
-6 pinion HD planet gears
-HD chain and sprockets
-DC4WD 2Lo Kit
-Custom HD SYE
-New custom CV driveshafts
-Novak cable shifter
Other:
-Early model overhead console with CB
-MV50 on board air with 1 gal tank
-Custom roof rack
-Custom 28gal fuel tank
-Custom gauge cluster with Intellitronix gauges
-New heater core
-New AC core
-Jeep OEM Ravine 15x8 wheels including spare
Things this jeep needs:
-RR axle seal is leaking. Replacement parts included. I just don't have the time
-Alignment is needed.
-Tires were balanced with airsoft BBs by the guy I got them from. Probably need balanced properly
-Shocks will need to be replaced at some point in the near future.
-Air line for the front ARB needs replaced.
M6b4Y2c
EjIQWQ3
rA2vg4Z
BEiOMtn
Reply here or PM for more info
Thanks
Jess
