97 XJ part out
SeanSS
Indianapolis IN
Parting out a 97 Cherokee
Not much left
HP D30 front axle that is wounded, needs the passenger side inner C replaced or repaired, otherwise good axle, 3:55 gears $50
Chrysler 8.25 rear, 3:55 gears $80 - Needs brakes
OEM steering-Complete- $30
OEM coil springs (2) - $20
OEM leaf springs (2) - $30
OEM steering gear box - $60
Most if not all of the plastic/metal interior trim/panels, Blue in color- $15
Rear blue carpet - $10
Dash- Will include air bag, dash pad, radio bezel - $50
Heater box/AC evap assembly - $40
HVAC controls - $40
Cluster -Mileage unknown- $25
Steering column with wheel and steering shaft - $30
E-brake interior assembly - $5
OEM Luggage rack with both cross rails - $15
Gas tank with pump and complete filler neck - $40
Cruise control module - $5
Driver side fender - white - $15
Hood- white- passenger side damage $15
OEM aluminum wheels + steel spare, 3 decent tires - $100
4 door seals + hatch seal - $5
4 OEM Fender flares - $10
Both Rear bumper plastic corners - $10
Front/Rear bumpers - $10 each
Rear cloth seat - dirty- $15
Header Panel - 1 crack towards drivers side of "Jeep" - $35 with black grill.
Master cylinder with brake booster - $25
Air bag control module - $15
Rear seat belts - $5
Front/Rear floor mats, Rear being OEM- $5
Gas/brake pedals - $15
Dash/Interior wiring harness - $20
Interior/Rear wiring harness - $15
(2) Sun Visors, blue cloth $5
If you need a body part, get ahold of me and i'll do my best to cut it out.
(A,B,C,D pillars, roof, floor, ect..)
I am located on the west side of Indianapolis.
Minutes from I74/I465
Message me with specifics
I am available in the evenings and most weekends
