- on the beach in Ocean View, VA
You're right, EGR's were from 1984-1990. Here's a link that tells more about the Chrysler recall.
http://www.jeepforum.com/forum/f13/97-zj-stalling-not-fixed-after-6-months-help-please-522719/
This recall was for Jeeps between the years 96 and 2001. They recalled 500,000 vehicles in that recall, extended the warranties for another 700,000 vehicles, then sent letters out to over 300,000 more to let them know about potential catalytic converter problems. Thats 1,500,000 defective vehicles they put out on the road.
I was wrong about the EGRs but if you have a defective cat on your car then your car isnt going to be able to breath. It's going to clog your car up with Carbon, mess up your O2 sensors, your MAP, MAT, TPS sensors and every other sensors that are also connected to your computer which it will also mess up.
It can also mess up your transmission as well. A blocked catalytic converter can cause symptoms of slipping, a bad PCS, a bad PCM, a bad TCC, and a whole host of others. You have to drive it a lot harder to get the same performance out of it and that will tear it up a lot faster than normal.
I think that all the problems people are having with their Jeeps have started out because their catalytic converters were not doing their job and that part made the rest of the parts fail. Chrysler pretty much sold millions of cars out there with a potato stuck in the tail pipe and didnt tell us about it because they didnt want to have to fix it.
Does that make any sense or is it just me? Wouldnt a clogged muffler cause all the problems that people are having with their cars to where they just stall out when you're driving them? Wouldnt it mess up all the sensors and the computers they were hooked to? Thats why they dont know what exactly is tore up on your car because it could of tore up anything. Thats why one car can be fixed one way and another car be fixed the other way. If they never had a defective catalytic converter on them in the first place then they would of never had the problems they are having now. Right? What else could explain all the Jeeps that no one can get to run with out dropping thousands of dollars into?
I think that if you havent had problems with your Cat yet that its just a matter of time before it does mess up or tears something else up in your car. I've had old cars before and never had to clean carbon out of them. If you still have one of the recalls then I would go ahead and get it out before it turns into a lot of money.
Like I said before, I dont know anything about being a mechanic, just what I've been reading the last few days. Tell me if I'm off base here because I dont know for sure. If I am right though then I think Chrysler needs to man up and extend that recall to a lot more people than that million and a half. They knew damn well what was going to happen and I dont think that we should have to pay money out of our pockets for their mistakes.
As mentioned, a clogged cat can be EASILY diagnosed with a vacuum gauge and the ability to read it.
Yes, clogged exhaust happens but it isn't the root cause of many driveability issues.
You can guess all you want but I would recommend that you follow Tim and Joe's strategy above. That is methodical troubleshooting.
Never noticed it but I did notice that if I was in town or sitting at red lights then it would start to over heat. It has a new radiator and everything else in it so it shouldnt have over heated. Wouldnt a clogged Cat do that?
it seems that you are fixated on a blocked/clogged converter. Take the time to check for decreasing engine vacuum and inspect the converter for signs of restriction (glowing orange) and post the results.
Although the converter media breaking apart can cause it to become plugged up, nothing in the recall you posted addresses it stopping up. It only mentions the converter becoming less effective as the substrate exits the converter.
