Talyn
- Radford, Communistwealth of Virginia
I have two sets of fuel injectors available.
1) Set of 8 Bosch/Ford XR3E-C5B 25lbs @43.5psi for stroker or better: $180+ free shipping in the US.
2) Set of 6 Bosch/Ford XR3E-A4B 22.8lbs @43.5psi for stock or stock with bolt-ons: $60+free shipping in the US
First set are 8 Bosch 0280155865, Ford XR3E-C5B 24 LB Mustang Cobra injectors. 4-hole
These injectors were cleaned, flow tested, and flow matched 200 miles ago. They are just too large for my stroker. They have been removed from the engine and cleaned. Like new with less than a tank of gas through them. They are EV6 style with 4 holes and a USCAR connector. They are suppose to flow 24lbs @ ford's 39.5psi. They flowed more on my 49PSI rail. Like 26 lbs.
Same ones as here for $308 for 8 or $239 for 6: http://www.fiveomotorsport.com/fuel-injectors/?itemid=1180
I'm selling all 8. Two unused.. I guess for extras.
$180 + free shipping.
Other part numbers:
XR3E 9F593 C5B
Bosch 0280155865
XR3E Cobra
The second set are 6 Ford/Bosch XR3E A4B. These were too small for my stroker and will work better in a stock or slightly modded engine. These injectors were cleaned, flow tested, and flow matched 100 miles ago. Like new with less than a tank of gas through them. They are EV6 style with single hole and a USCAR connector.
Other part numbers:
XR3Z 9F593 A4B
XR3E 9F593 A4B
CM-4956
9F593, FJ441
Other part numbers:
XR3E 9F593 C5B
Bosch 0280155865
XR3E Cobra
Other part numbers:
XR3Z 9F593 A4B
XR3E 9F593 A4B
CM-4956
9F593, FJ441
