Speaking of temperature measurements, gauges and sensors, I went to Harbour Tools today and bought a small, key chain size portable, infrared temperature tester for $9.95, on sale. It has a range limit of -27 F to 230 F, but the price was right and it is real easy and super fast to use. Don't know how accurate it really is (claims +/- 2% or 2 C at an ambient of 23 C) but I was pretty impressed after using it. The readings were very repeatable.
I tested my Gauge Temperature Sender (GTS) and Coolant Temperature Sender with an ohm meter and they read, 280 ohms on the CTS and 252 ohms on the GTS. The FSM says that 160 F is 450 ohms, and 212 F is 185 ohms, and 100 F is 1,600 ohms.
Both sensors (the CTS and GTS) use the same variable resistance temperature device and have the same resitance at the same temperatures. Unfortunately, after plotting the temperatures from the FSM in Excel they do not appear to be linear (so it is not a typical thermistor, which as I recall is linear, so it might be a thermocouple(?), so I am not sure exactly what temperature 252 or 280 ohms is. If I had to guess I would say about 180 to 190 F. I have a 165 F thermostat currently in this jeep (as best as I recall).
The gauge indicator was just barely below the second notch or line above the 100 F mark and just a bit more that 2 notches below the fourth mark which is labeled 212 F. Therefore, it seems clear that not only is the Thermocouple(?) non-linear but so is the gauge!
Has anyone ever mapped out the intermediate marked values on the water temperature guage between 100 and 212 F or from there to 260 F? My 1987 gauge has three notches between 100 and 212 F. I know now that they are not linear and that the first knotch is about 160 F, based on the infrared temperature readings I got today, and the second notch is about 190 F, at least with my current sensor, gauge and infrared meter combo.
Do these numbers and readings corelate with your alls readings?
Based on todays tests I now realise that my engine has been running at 160 to 190 F and not at 130 to 160 F as I previously thought.
I took a variety of temperature readings all over the engine bay. The upper radiator hose was typically 20 F cooler than the thermostat housing. I took readings all over the engine block, top right, left and middle of the radiator, intake manifold, valve cover, etc. It was quite enlightening to see the temperature variations all over the engine.
I think the $9.95 was well worth it.
