ZombiE
- Fort Walton Beach, FL
Hi everyone, new here
Problem Part 1
I just installed a cruise control system for my Jeep. It is the exact same kit that the dealer used to install. It is/was made by mopar and it came with a dealer instruction booklet. It has three pieces to it. The switch panel, that mounts under the airbag, the vacuum canister, in the engine compartment and a new clockspring. Everything plugs into the factory wiring harnesess.
I installed the units and it will not work. There is one light next to the on/off button that will not light up. I checked at the back of the connector leading to the switch panel, I do not have schematics for the cruise control, but I did have 12VDC on one of the pins.
Anyhow to make a long story short, are there any other items I need for this unit to work? I put fuses in the three empty slots on the fuse panel, just to make sure I was getting power, but in the Haynes manual (Junk) that I have it does not list anything for the cruise, they say to take it to the dealer. Am I missing a relay somewhere or the input from the computer or something. There are only two connection to this install. One at the back of the switch panel and one and the vacuum canster.
Part 2:
Received the Jeep back today and they told me that the switch assembly, the one on the steering wheel was shorted out. Well I brought the Jeep home and took the switch apart. I didn't want to chance breaking it before I took it to the dealer. There is a curcuit board with three switches and 5 resistors.
Just a tad bit of background info: I have been an electronics tech for over 13 years.
Ok, back to the story, so I ohm'd out the switches and the board with nothing wrong with it what so ever. Hmmm, The guy at the jeep dealer told me that is what the "Computer" said was wrong. They can order a new switch and put it in for $87.79 and if that doesn't fix it, it won't, then they will have to start trouble shooting at $57.00 an hour, screw that with wet poop on a stick.
Anyay, I am begging for someone with 95 Jeep, or years around that, with a scanner to please scan trhen schematics and email them to me. Please!!!!
I am ordering the Service Manual for the Jeep but I can't do that until next week. Plus I can't find any where around here that sells Chilton Manuals, they all carry Haynes, which I already own.
Thanks goes out to anyone that can point me in a new direction,
Alex
Problem Part 1
Part 2:
Alex
