'93 toyota p/u front ifs pumpkin
Special Ed
NAXJA member #966
Everett,WA
I have two toy p/u's (7.5" ifs) that i need to swap differentials with. Can someone please give me a short description on the easiest way to pull the axles?
Thanks
You need to get the shafts pulled by removing the hubs and rotors then spindles. Pull the lower crossmember and driveline then the diff should unbolt an drop out.
