I have bought a Wrecked 93 Cherokee Country with 200,000 miles. Started right up after sitting in a garage for 2 1/2 years. Smoked a bit at first, but cleared up by the time I drove it across town. This may have something to due with the old gas also.
I have a 90 Cherokee with a 3 inch lift on 32's that runs but is getting fairly weak. I would like to pull the HO and put it in the Renix with the renix injection system. I dont feel that the HO adds enough to deal with all the picky sensors. I would be swapping everything that fits, including the AW4 and Tcase.
I plan on doing a refresh of this motor, ie. rings, seals, bearing and gaskets prior to putting it in. What head would be best to use and what modifications do I need to do to it to make it work. Would I be better off using the Renix head? As always, trying to do on a budget, so not looking to do any expensive performance boosters.
I have read somewhere that the HO was around a 15 HP gain over the Renix, and that using this head can gain you back 10 HP over a stock Renix. I do have the Ford injectors installed on my Renix.
I would like to hear from some of the experts on here about what the best avenue is going to be for me.
Thank you in advance for your advice.
