- Ocala, FL USA
So you'll be ready for the Crawl again right?
Did you check ball joints? That was the source of my DW.
Yeah. Steering, trackbar, balljoints... not much left there. Would suspect caster angle is the culprit then although with a 3.5" lift I'm surprised (unless I missed something? latest pictures look taller). Unless the taper for the 1ton steering wasn't done correctly and you've got movement there?
Have patience. Took me a year to get mine fixed. Meanwhile I was driving it back roads to work cause I had to.Right. And I confirmed the correct reamer for the TREs and made sure the knuckles and stuff were reamed out at the correct depth. I believe I had too much castor when I was test driving. It was near 9 degrees which is too much.
I have researched so much about the castor issue that I understand that castor, wheel back spacing and tire width have a pretty big factor on how the front end tracks down the road and which way the forces are acting on the wheel/tire. If the force is too overwhelming then boom terrible death wobble. So I am going to try and get the castor around 5 degrees since less castor is needed with wide tires.
I called around the Hampton Roads area for a quote on a wheel alignment and Eastern Offroad has the best deal at $80ish for the job. I called the new 4WP and they said it starts at $135. Plus the time I went to Eastern Offroad they seemed more customer friendly. Even though they don't do custom fab I believe they can get it dialed in right. I think one of the MJs flexing out front is an employees and it is pretty custom fab so I trust them more over 4WP at this point.
My fingers are crossed because I am not financially ready to buy truck or suburban to tow just to go offroad.
From what I read too much Caster should not cause the problem. I still think it's a loose part somewhere. Something has to allow the side to side movement.
After this week the only thing left I haven't replaced are unit bearings. While they are old I just can't see them being loose enough to cause death wobble. If they were that loose then I figure they would have separated by now.
I even replaced my steering shaft from the steering wheel to the steering box with a new one because I thought it could be the reason.
I have laid under the jeep in the garage holding onto different parts of the front end as someone goes crazy on the steering wheel turning it back and forward and still don't see or feel movement :dunno:
Unit bearing will never separate as long as there is a shaft in there. What about control arm bushings and the axle bushings?
Is fender trimming next or do you plan to add a little more lift? Those tires fill up the wheel wells. Looking good! I like the look of the JK wheels and the Duratrac tires.
I was looking through some of my subscriptions and thought about this one after seeing the possibility of looking for more clearance in the rear. Food for thought.
http://www.naxja.org/forum/showthread.php?t=1011630
Mark's "" rig at the Crawl last year sports a rear trim done by Stump. You may have seen it.
