Nothing has come loose, seems fine, just I was told there is an unusual (not typical) issue with the engine mounts. Difficult to find engine mounts to the engine on the passenger side, might you know the socket size?
Whoever told you this is probably talking about the brackets that mount to the block. They will sometimes break, or the bolts will shear off. I believe there are only 3 bolts attaching the factory brackets to the block.
You can do an inspection of the brackets and check the bolts, too. I don't know the socket size offhand.
BrownDog and Stinky Fab Racing make different brackets for the 4.0, if that becomes a concern.
I just replaced mine after I found two bolts with their heads broken off and one of them stripped out.
They're a 9/16 head. If you look down and don't see any suspiciously missing you're probably fine. I've heard you can check for a gap between the bolts and the bracket or between the bracket and block with a feeler gauage if you're concerned about them coming apart.
