It's a little nippier than usual (I live on top of a mountain) so it took a little longer to get warmed up, but it started.
When I clicked on the key, no fuel pump or check engine light at first, then slowly (as I turned the key multiple times) I could hear, barely at first, a low purring noise coming from around the direction of the relay box/pdc thing. At the same time, I left the key on, the check engine dummylight in the dash started to fade in & out, and the 'purring' sound got louder, the fuel pump and check engine light, woke up at the same time. Primed the pump by turning the key few more times and it started up.
WHATEVER this is, the check engine light in the dash and the fuel pump are related as these are the only things that don't work when the cherokee is cold. Does the check engine thing have some type of sensor somewhere and could this be the problem that doesn't allow the fuel pump to engage? I don't know I am not a mechanic.....also, again, there is no fuel at the schrader valve at the rail while this is going on.
Where is the temp sensor? Is it on that side of the motor? THANX in advance for all the suggestions....
