Don Becker
- Beaverton, Oregon
The bright headlight beams (both) (two headlight system, not four) do not come on. The headlights themselves are okay. The low beams work just fine. All other lights, signals, etc work fine; including the blue high beam indicator light. I'm getting no voltage to the headlamps when the switch is in the high beam position. 'Seems obvious to me that the turn-signal/wiper/bright-dim switch needs to be replaced in the column. BUT, I just thought I'd check-in with you folks to make sure I haven't considered some relay or some other item/cause I might not have thought of. Thanks! Don
