Elfwizard1975
- Washington
Whats tha IAC?
Elfwizard1975 said:I know I have intermittent fuel pressure. But I am trying to figure out if its the pump/check valve or Fuel pressure regulator. Before it started this I did have a hard start condition, had to cycle the key twice before it would start. I am going to go buy more parts tomorrow and work on it again on Friday.
The check valve is built into the pump.Tweeternpi said:No, It did not come with a check valve. It came with the pump and a new sock, and a new hose to go to the hard line in the take. Not sure where a check valve would go.
I hope you fine something, If I come across the answer I will let you know also.
Yucca-Man said:One thing that's been overlooked....how cold is it there right now? I remember back in early December when we had a similar severe cold snap there were quite a few problems with no starts.
It's -2*F here right now, and I have no doubt that if I were crazy enough to venture outside and try to start it, my Jeep wouldn't start. It's a cold weather thing, and I don't think there was a good fix ever found for that (unless you park it in a warm garage, that is)
