'90 XJ Fuel Gauge acting up
tjmotter
Texas
Looking for insights on where to look for an issue with a '90 XJ 4.0L.
Symptoms:
- when full, the fuel gauge seems to act normally
- at 3/4 of a tank, the gauge shows full
- at 1/2 tank the gauge shows a little less than full
- at 1/4 tank the gauge still shows a little less than full but will randomly peg the needle almost to the bottom of the gauge, back off and then do it again
Not the best way for me to recognize I need to fill up ;-).
This is a new issue. The gauge has worked perfectly up to now. This vehicle is very lightly used (maybe 500 miles per year) and can go months without starting. I keep it on a battery tender and locked up safely in a garage so there is no exposure to the elements.
Not sure where to start on this one. My initial thought was to remove the gauge cluster and clean all the contacts but when I first bought this XJ, it was very tough to start and I found that the short rubber hose that connects the fuel pump to the outlet in the tank had come loose causing a fuel pressure issue. I am probably over thinking this since the XJ runs like a dream but am wondering if this problem has re-occurred causing a high pressure flow of gas to hit the sending unit when the tank is low.
Pulling the pump is my last resort. Hoping y'all can give me some ideas on other areas to check.
thx
Sounds like the typical old sending unit !!
The especially early xj senders could be a bit random. I'm not sure anything is actually wrong.
The plugs to back of the cluster can tarnish, an eraser can help renew them.
I've never had this fix work because my 85's sending unit was the problem, found a 86 unit NOS and then had to redo the plug to match the new sender which led to other wiring troubles.
If it's suddenly wonky maybe there is tarnish on one end, sender or cluster. My experience is the wires going to the cluster are usually ok, body harness from under the passenger seat to the plug near the fuse box are usually ok.
Oh, I think there is a ground that affects the sender in the body panel behind the spare tire.
After 30 years mine didn't look bad at all. But others have had problems with it.
Thing is even with a lot of NOS parts and new (used ) dash harness , best I can get it the fuel gauge is still twitchy, which is a lot better than it was when I first got it. For example it would randomly twitch just sitting at idle. Almost like it was the jeeps pulse.
New sender is a lot better but as the tank sloshes it can jump around more than any other car I've owned.
Drive it over some washboard roads with the tank less than half full and see what happens.
Dump some cleaner in the tank with a full tank of quality fuel and see if that helps. My '87 had probs with the gauge cluster (corrosion or rather lose of contact with the contact board/sheet). From what your explaining though I bet your sending unit is tarnishing.
My sending unit is trashed.
but I am a lucky one. it works enough that its not worth replacing yet... the replacements get expensive. I think like $200.
1/2 tank is full to 1/4
anything less than half a tank is less than 1/4
and the fuel light. means 2 more gallons.
I am still looking for one better than mine.
but I would suggest a junkyard run.
they always seem to be gone by the time I get there tho.
wonder why... $$$$
If it is constantly reading higher than the tank level at the gauge, I'd start at the instrument cluster contact strip and try to clean the connectors front to back. Then check the ground at the pump. Cleaning that contact strip is a TSB.
The higher the resistance the higher the fuel gauge reads on Renix (and even some YJ's).
Should read 88 ohms full tank, 0 ohms empty tank. If you check it at the pump and make sure your ground is good, it should tell you if it is in the connectors or the sending unit.
I forget the exact count but around 4-5 connectors between the cluster and fuel pump module and a couple in the ground circuit. Note: if you ever have occasion to try and troubleshoot that circuit the wire colors change in the middle and then change back again at the end. Which gave me fits the first time I tried it.
AWESOME! thanks!! I will measure it on Monday when I get back to the XJ. Your note and the one below on the possibility of tarnish build up have me thinking. The tank is currently full so I will look for 88ohms but when it starts acting up again, I will put the meter back on it. I only use the XJ occasionally and then only for short trips. A tank of gas can last me 6-8 months. It is possible (even likely) that sitting for so long could have caused a tarnish build up on the sending unit wires causing it to give bad readings. It is also possible that when it got below 1/4 tank (which is where I would estimate it was when I filled it last week), it hits a spot where the tarnish had coated the sensor wire to the point that it gave readings much higher than 88 ohms which would explain the gas gauge pegging.
I think I will also throw a bottle of Seafoam in the tank to see if it clears it up.
I should add that I completely rebuilt the XJ a couple of years ago. At that time I stripped it to bare metal, fixed a couple of rust spots and repainted it. I know that I checked the chassis ground at that time so I am sure it is still good.
thanks again!
Todd
