Economos
- Coastal NC
Ok, this vehicle has been my DD/ trail vehicle since I turned 16. The Jeep needs upper balljoints last I checked (could possible need lowers as well), a new driver-side unit bearing hub and a heater-core. AC runs but isn't very cold.
Specs:
- 1989 Jeep XJ Cherokee; 4 door
- 4.0 Liter
- AW4
- NP231
- HP Dana 30/ Dana 35
- Midnight blue paint
- 270K miles; rebuilt @ 205K
Aftermarket:
- RE 4.5" coils (netted 5" settled)
- RE adustable trackbar w/ heim
- RE SuperFlex adjustable LCAs
- 3" Rusty's leafs w/ 2" blocks and 1.5" shackles (netted 6" settled)
- TeraFlex TJ long travel shocks at all corners
- Home made f/r bumpers
- hacked fenders
- CRS weld on rock rails
- 33x10.5 BFGoodrich MT/km on 15x8 TJ Canyons
- JKS disconnects
- GDI 3-core radiator
- Ford 19lb injectors
The oil has been kept changed on a regular basis with Mobile 10w30 and K&N filers. There is nothing wrong with the engine, trans. or transfercase (although the fluids probably need to be changed in the trans and t-case). The 4.0L runs fine and the AW4 and 231 shift smooth as well. The carpet and headliner have been removed for Rhino-lining, but I never started on the lining. It has been wheeled in Uwharrie and in a few other trails around NC; some mud, but mostly rock.
New parts added this year:
- stock exhaust manifold
- water pump
- harmonic balancer
- altenator
- battery
- serp. belt
- starter
- front pass. unit-bearing hub
- front pass. caliper
- master cylinder
- Bosch O2 sensor
- Bosch plugs and wires
- Ford 5.0 19lb injectors from Summit
As I said, the vehicle is no where near perfect; there have been many parts I have replaced over the years in order to maintain its DD duties; some new parts have been added with in the last year. If you want specifics, feel free to e-mail me at [email protected] or PM me and I will be more than happy to answer your questions.
I'm asking $2k obo as it stands; I'm located in Wrightsville Beach, NC 28405. Thanks.
Specs:
- 4.0 Liter
- AW4
- NP231
Aftermarket:
- hacked fenders
- JKS disconnects
- water pump
- harmonic balancer
- altenator
- battery
- serp. belt
- starter
- master cylinder
- Bosch O2 sensor
