agattoblanco
Hey all first queston here.... i purchased a 89 renix xj a few months ago not running.
I have changed the gas tank, fuel filter, fuel pump and new cheap injectors to get it running... runs ok
Heres my questions ... i put water into the over flow / pressure tanks for the cooling system.
The overflow tank then bubbles like crazy and the water dis a pears ive filled that guy three times ( i realize it needs 3 gallons but i get pretty worried when it bubbles like crazy and then is gone. ) and the water disappears then there are no leaks and the oil is not getting infused with water.
1 Is this normal ?
2 what is the proper/best procedure for filling the coolant level
3 I put water in and gone... Could this b a head gasket ?
1 Is this normal ?
