89 Comanche Eliminator BA10/5 yoke
85Wagoneer
New York
I've been hunting the forums for a while and can't find what I'm looking for. I have the much despised Peugeot BA10-5 transmission from a 2 wheel drive MJ swapped into my 85 Wagoneer and bolted to a 4.0 liter from a 2001 Cherokee. It's been a ten month build and I finally got sick of dealing with wiring for AW4's and the BA10-5 was available. Now my project is sitting because no matter how hard I look I can't find the end yoke to bolt on to the output shaft of the transmission. If anyone here has any idea where to look I'd appreciate the info. All I know is that it's a 21 spline non-slip yoke with a diameter of .99 - 1.03 inches.
And yes, I know the Ba10-5 is an underperforming weak turd. But so is the rest of the Jeep.
Are you talking about the slip-yoke that is attached to the driveshaft? If so, it just slides in.
Should be the same yoke for most all heeps.
It is the driveshaft end yoke at the trans, but it's not a slip yoke. I have the slip yoke from the 2001 AW4 transfer case I use to have but it has a larger internal diameter and too many splines.
